haywire4130
- Sep 11, 2010
Hi all, went to the track friday and after a pass on the way back to the pits my car went full rich and started sputtering- xfi showed a code for "map voltage" and the alky turnon light was flickering red, afr bottomed out at 9 something and wouldnt stay running. Im running a 3.5 bar AEM map sensor thats only a few months old, wiring from xfi to map is straight from xfi box to a deutsch connector to the sensor and is brand new wire, wrapped in split loom and very carefully routed (im anal about wiring). The green map signal wire is tee'd in just before the map sensor, soldered and heat shrinked. I confirmed car still ran bad then snipped that green wire when i got home and the car started and ran normally. Ive had this problem before intermittently a few times which is why i went from the suspected bad gm 3 bar to the aem map sensor. I was previously running sd2 and scrapped that whole setup last year for xfi because i thought it was a glitch in the chip. I'm leaning toward a problem with the alky wiring or the alky control box itself, both were on the car when i bought it in 08 so i dont 100% trust the install. Any tips on how to diagnose without hucking parts at it? I'm fine with replacing the control box if need be.
