Internal Balance Super Dampener
Spongebob
Buick Abuser
I just got off the phone with ATI Transmissions regarding their Super Dampener applications.
I have a BMS Crank so I need an internal balance flywheel and harmonic balancer. ATI tells me that their part number #918051 will work for my application.
Anyone else using this?
Thanks...
Ask about the crank sensor ring. I have one of these balancers and it's nice, but the crank sensor ring had to be added. If they sell them with the ring, that would be much easier!
The low buck option is to use a steel hub with the ring; lots of the Busch and ASA circle track motors used these. Depending on how much you plan to race it and how much of a Nazi your track tech is, they may not like these without an SFI stamp.
BHJ makes an internal balance damper w/the ring installed also.
