scot w.
GNSperformance.com
- Feb 19, 2005
Well first of all before people tell me to read, Iv'e been on here well over two hours reading stuff and writing notes.
My question is on the turbo size! (TE-44) I looked for people that had a similar set up but seen mostly larger turbo's.
With my (TE-44) turbo I would just like to run 22lbs on the street. WOULD 60lb INJECTORS WORK for that size turbo & boost? I know I have some engine work done but not exact on the cam specs or the porting of the heads.
Would I be okay with my injectors by going 50/50 (93/e-85)?? Just looking to go from 15lbs to 20lbs!!
Here is my set up:
Turbo: TE-44
Injectors: 55lb
Fuel pump: Walbro 340m
Hot wire kit
Converter: 2800
D/P: 3"
Exhaust: ATR 3"
G-body S.L.I.C
has a cam (specs unknown)
Carrilo rods
J/E forged pistons
From what iv'e read already it looks like all i'm going to need is LARGER INJ, TT chip. RIGHT?
Scot W.
Here is my set up:
Turbo: TE-44
Injectors: 55lb
Hot wire kit
Converter: 2800
D/P: 3"
Exhaust: ATR 3"
G-body S.L.I.C
Carrilo rods
J/E forged pistons
Scot W.
