Low Budget
- Apr 10, 2002
Originally posted by jdodman
Before you give yourself a heart attack, are you sure it is not false knock ??
I broke the support arm for my CAS intercooler at WOT, at the track, which had my entire intercooler ratteling against the front sway bar. It was registering 15 at the end of my run on the scanmaster.. I thought the engine was toast, until I figured out it was just the intercooler ratteling around.
Look around your engine compartment and see if anything is loose that could be banging around.
BTW - There is an excellent mechanic for our cars right here in Warminster PA. In case you decide you want to spend the money and have someone who knows these cars inside out.
Dave Heintz at Warminster Auto...
Originally posted by salvageV6
I'd check you motormounts.
Last time I had KR in the 30's the bolt backed out.
See if the motor torques over in gear in the driveway.
Use the brakes and open the hood.![]()
6 knock is a lot, 1 knock is a lot
