I've got a TA-49 that needs a rebuild and just want to make sure it's able to be fixed. There is only side to side play and it scrapes the walls. Thanks.
Originally posted by mike I've got a TA-49 that needs a rebuild and just want to make sure it's able to be fixed. There is only side to side play and it scrapes the walls. Thanks.
You mean it has hit the compressor or turbine housing? If it did you may need a new shaft, new compressor wheel and compressor cover. It can be rebuilt but if the damage is enough you will have close to a new one in it.
