So sitting here wondering what I might run at the track now that all of this is installed and running good. Any guesses? Is there anything else I might need?
PTE GEN2 PT6466 CEA Turbocharger
PTE HD Wastegate Actuator
PTE Turbo Saver Remote Oil Filter Relocation Kit
Alkycontrol Methanol Injection System
Eric Marshall TurboTweak Chip
Siemens 60lb Fuel Injectors
Powerlogger Scanmaster 2.1
PTE Super Stock Location Intercooler
Accufab 70mm Throttle Body
PTE Ported Intake Plenum
RJC PCV Check Valve
TA Performance 3" Stainless Steel Downpipe
Internal Gate Performance Headers
Cat Back Exhaust
Accufab BREG Adjustable Fuel Pressure Regulator
TR Custom Parts Big Mouth Cold Air Intake and MAF tubing
LT1 MAF
MAF Translator
Racetronix 340lph Fuel Pump Sender Assembly
Racetronix Fuel Pump Hotwire Harness
PTC GN Spec Lockup Torque Converter
Extreme Automatics Lonnie Diers Built Stage 3 200-4R Transmission with electronic trans brake and external cooler
GBody Parts 3.5" Aluminum Driveshaft Driveshaft Safety Loop
Moser 28 Spline Axles
TA Performance Low Profile Differential Girdle
HRPartsNStuff Super Swaybar and Control Arms
GBody Parts Vacuum Brake Conversion
GNNW Spec Upgraded Pads / Rotors GNNW Spec Upgraded Rear Brakes (S10 Cylinders)
Alradco Aluminum Radiator Alradco Dual SPAL Cooling Fan Kit
GBody Parts Mini Starter Kit PowerMaster 200A Chrome Alternator -
Turbo Buick NOS Serpentine Belt Tensioner Highway Stars Replacement OEM Ignition Module /
Coil Pack Magnecor KV85 Spark Plug Wires
Hurst Line Lock
all on a 275X50X15 ET Street
RJC PCV Check Valve
Cat Back Exhaust
LT1 MAF
MAF Translator
Hurst Line Lock
