Pics
Here are some pics of my painted intake and quickly thrown together setup on my driveway. This is the JS intake with 87 TB and TA33 with TA style inlet bell. Some port work done as well to take out the factory roughness from the runners and match up to the ported heads. Gasket / port matched to the fel-pro 1200's.
The intake is now on the car - but I ran into a problem with the bottom of the TB hitting the thermostat housing. Time to figure out a fix for that. I also notice that the aluminum accessory bracket (holds alt, A/C compressor etc) is directly in the way of where the pipe must travel to hook to the TB front after exiting the IC. I figure the sawzall will fix that.... :biggrin:
