While it's taken a while the 1227749 Syclone ECM has been taught to speak DIS.
With some new items on the market it is also real time tuneable.
It's not EZ, or really cheap, but it'll be available soon.
It takes getting the 749 ecm, a syclone memcal, an adapter harness, and the normal chip burning stuff, to include memcal adapter, and the Real Time tuning bits but it's still 1/2 the price of an aftermarket. Plus I'll be releasing Source Code to go with it, which is a first anywhere. With actual source code, the actual operating insturctions can be changed. And there is alot of room for adding routines. The only agreement is not using the related Source Code for profit, and sharing any developements with it. It's a hobbists thing.
Like I said I've got the timing taken care of,
and, the fuel is figured out, and the TCC stuff verified.
I still want to put some more miles on it, just to be sure about it all, but it's basically a done deal, other then putting all my notes together, and getting that posted.
Yes, it's a batch fire set-up.
Yes, there are P+H driver updates available for it.
Yes, Turbolink and well as any Syclone scanner works fine on it.
YES, there is a patch for datalogging a WB with the normal scanning stuff.
I'm using 7 injectors, and an injector constant of 60 PPH and have full control of idle fueling at 800 RPM. I don't know how large you can go injector wise on this set up, yet.
TCC is fine.
By using the Source Code, and the A/C and EGR outputs can be used to turn other items on and off..........
Just a heads-up about what's around the corner.
TCC is fine.
