Knock check for a dummy
Paul Clark
If I have the alky spraying AND use race gas - any knock I get is probably false, correct? (I haven't tried the race gas yet)
Then can things go to the other extreme where I could still get knock because it's too rich?
ScanMaster recall had 17 (points?) of knock today with 825 02s. That ain't right. I only went about 50 feet from a rolling start.
Think I'll drill a hole in the hood and fill everything with that expandable foam insulation stuff.
Yes!
Sometimes something loose can set it off also. the trans linkage from that runs down to the trans from the column ring, was loose on mine and it would hit the header. Took a long time to find that one because it only happened under wot. I accidently hit it one day while searching for the cause. :rolleyes: :biggrin:
