Laptop screen size
Big88
I'm using Felpro {fast} system on my dell latitude with windows 98, But using Dos verson, The problem is I can't it to fill the entire screen. I have about a 1 inch border around the screen not being used. Anyone have an idea how to use the entire screen. Thanks for any help.
The DOS software is a fixed resolution of 640x480. In order to have it fill the screen there is a hot key of some sort on the laptop. What that hot key is depends on the laptop, if you don't know what it is you'll have to refer to your laptop documentation.
Be aware that if you do this, it will look bad because you are basically stretching the image to fit the larger screen.
