Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
These items were to be used in a conversion of a hot air car to intercooled. The person I was performing the work for has sold off the car and no longer needs these items. He has asked me to sell off the items. All these items were sourced by me personally to perform the work. All mechanical/electrical components were inspected and were from hand picked low mile donor cars.
Please contact me with the item and the item number VIA PM, they are all in numerical sequence and pictures will follow the listing. Shipping will be quoted via PM. Some items I happen to have a couple of, therefore they are represented x2.
1 New Metco Billet thermostat housing $25 *** SOLD*****
2 Power steering hard lines $50
3 power steering reservoir and lines $175
4 reservoir bracket $30
5 power steering pump and pulley $100 ***SOLD****
6 crank sensor and bracket $35
7 Y ac bracket, it is shown being attached to compressor $40
8 AC compressor, will need a new label, Y bracket will not be included ( in picture) $50
9 aftermarket fuel lines to rail both $75
10 powder coated water pump pulley x2 $40
11 throttle body $75 *****SOLD****
12 throttle cable and TV cable bracket $35
13 turbo drain line $35
14 wiring harness, no cut ends, very nice condition with L channel $400 **SOLD**
15 main accessory bracket with bolt for ac compressor $75
16 harmonic balancer $100
17 throttle cable $50
18 engine oil dipstick and tube $75 ***SOLD****
19 TV cable x2 $50
20 cruise control module and bracket $75
21 cruise control cable $50
22 heater hose hard lines, heater valve and hoses $75
23 fuel regulator (being shown attached to fuel rail) $35
24 fuel rail (shown as an assembly with the harness and regulator, will come bare)$75
25 Fuel injector harness (shown on the fuel rail, will come as just the harness)$40
26 front intake vacuum lines $50
27 rear intake Crank Case vacuum lines $35
28 turbo J bracket $75
29 upper plenum $30 ***SOLD*****
30 Alternator tree bracket $50
31 AC compressor L bracket $35 ***SOLD****
32 Coil pack bracket $40
33 AC Evaporator $75
34 Transmission dipstick and tube $75
35 Bumper grille filler $50
36 Pass side manifold $75
37 radiator top plate $75
38 crank pulley and spacer $50
39 positive battery cable $50 ***SOLD*****
19 TV cable x2 $50
