The way mine works is like this. I do the burn out and two foot
the car in two the stage lamp.Then i set the trans brake the
rpm trigger switch which is activated by the t brake turns on the
no2 at 3000rpm and off where i want usually 4000 rpm then the
two step takes over to control rpm while the gate controls boost
my problem is i cant dump enough boost due to waste gate size
now if i could bleed a little through the bov that would very nice.
A bigger waste gate is the solution but that means fabrication and more money.
i have the bov on the car already why not try to make it multi funtional.
controlling the bov will be the trick if i stray far from the proper spring size
it wont function as intended for initial purpose.
With a 2 step and an exteranl gate you cant control launch boost? what boost controller are you using? I am figuring the nitrous is off at the 2 step point.
With my XFI i was using the transbrake control,(was one of the first to test this back in 05 for F.A.S.T)
It ties your t-brake solenoid with a digital relay and the XFI has a PWM solenoid.
I would get into the first bulb,apply the brake,when i reached my 2 step, i would trigger the creep function and the car would simply roll into the second bulb with the transbrake applied.
It is a real nice feature,you can set it to creep as soon as you reach a certain KPA as to not creep to early also
