My car has been running great...... I have been having issues with traction lol!
I have also noticed the car huffing a Lil more than usual. It very well could be valve guide seals but they are fairly new.
I freshened the engine up about 3 years ago new seals gaskets, rings and bearing (due to blown head gasket)
Any way it looks like I have cyl2 burning some oil as it shows more so on the plugs than any other cylinder.
I wanted to do a leak down test to make sure the rings are ok. I plan to run the car in a few weeks. I don't mind if the car smokes a little and as I said it runs really good so I can't see it being a ring but I wanna make sure.
With all thy being said I have a differential gauge my uncle uses for the airplane engines he works on. Those engines have a 6" bore and I believe the valving in the gauge may be bigger than something I would buy for a car.
I have never done a leak down test...... But I was wondering if the valving was different would it cause an issue with the reading?
In other words.... If the gauge is made for a 6" bore would the volume of air be too much for a 4" bore?
Also do I test the cylinder TDC or BDC or does it not matter as long as both valves are shut ?
