I'm trying to get a new build going. I'm fighting an overly rich problem. I have noticed the fuel rail pressure going down to zero in a couple of hours. with the fuel lines pinched closed at the motor. The injectors are new from FT. They are the 60lb siemens/motron. Has any body had issues with these injectors?
below is my build
87 T Type
109 block .030 over
steel main billet center caps
Diamond Racing .030 Turbo Buick Piston Set
Dianmond Pro-Select .030 Ring Set
Camshaft 208/208
Champion Heads & Intake
9:1 compression
70MM Billet Throttle Body
Precision TE-44
THDP
Snow Performance Alky Kit
Eastern performance FMIC
newest design Walbro intank pump
Racetronix FP Hot wire kit
60 lb Siemens/Mototron
Scanmaster
Direct Scan
Extreme G Chip
Gen II Trasnlator
3.5" Maf
below is my build
87 T Type
109 block .030 over
Camshaft 208/208
9:1 compression
Precision TE-44
THDP
Scanmaster
Direct Scan
Extreme G Chip
Gen II Trasnlator
3.5" Maf
