T66Typhoon
SUV Pimp
- Feb 2, 2003
Well I am glad that seems to have helped.
As someone recommended before... I think you still have TPS issued. Also what you did with the AE setting is not going to work, I don't think... that seems way too high.
I think you still need to get the AE settings right per what I mentioned before.... that would have nothing to do with your AE being added. Are you sure that your TPS max idle is still set to +2 above your idle setting on the TPS?
Boy I would really like to see your car in person, the only thing that I can think of for you having to use the 80 numbers down that low in the map is that you have the IAC open or some other source of air ... That is odd... seems like that would make your idle high... but seems weirder things have happened.
Do you have someone with a similar TPS and Throttle body that would be able to swap out with you and see if you can get your TPS in a good range.
