Hello guys,
Looking for some help with a problem or something i overlooked.
Long story short this was a running drivetrain till now. I have did my best to wire it in with my factory SS. My problem now is that she wont stay running. it seems to be loading up real bad or something.
If I pull the chip she starts rite up in limp mode and runs. I put chip back in and it farts, pops, stalls..
Quick little info on setup is that its highly worked up. Stock ECU was sent to Quad Air (Red Armstrong)by last owner. Its was moded to except any injector and has the R93 chip in it. After calling Red it has 55lbs injectors. I told Red my problems and he says its not the Chip. Car wont stay running long enouf to set any codes. I pull chip and keep it running only code is for no prom.. I have tried different MAS, ECU (with and without the chip) and it does same thing. I other ECU i have had a chip for 42lbs injectors only. With the 42# chip witch i know is not rite it all still does the same thing.. Hmmm? So is it something i did? Something may of went bad in year it was all sitting around? Any help would be great..
Thanks Guys Jim..
Thanks Guys Jim..
