CzyKats44
This is the way.
- Jun 28, 2014
Hot air, no start.
History,
Recently bought this 85 GN. Noticed a newer crank sensor but didn't think much of it (old one in box in trunk). Have not driven it except off the trailer, and in and out of the garage once.
A few days ago, back it out of the garage and shut it down. Then it cranks but no start. (Good fuel pressure at the rail, dry plugs) Ran through all the C3I checks in the factory manual with test light and/or meter, and the tree clearly pointed at crank sensor.
Just to confirm, I hooked up my Caspers C3I box, no crank signal. (Power and cam good)
Replace crank sensor set gap to .030.
With box hooked up, it started and ran with the lights showing proper sensor operation.
Removed box and hooked up 14 pin back to the icm, cranks but no start again.
Reconnected Caspers box again, crank signal is now gone, again. (Power and cam good)
(Counting the old one in the trunk, that's 3 crank sensors in a short period of time.)
After I rotated the ring to the position is should light, I did a serious wiring shakedown with key in run to see if I can see something flicker, nothing.
Ohmed out the crank and 14 pin connectors, all checked with no or inconsequential resistance and rock steady...
I also tried swapping in another known good ign/coil pack, a good ESC module and relay, still no
All the parts that this began with went back in after there was no change.
I'm open to ideas. Thanks!
Sent from my Spaceship.
History,
