I was under the assumption that the PL would log my boost through the standard connection. I am running the stock map sensor and my stock gauge works......I don't use the stock gauge I have one on the pillar for accuracy.
What do I need to hook up or turn on to log boost pressure? The only thing that is not hooked up is the stock boost solenoid....its plugged in but there is no pressure line to it. Is that the cause?
For clarification....I do need to run a 3 bar map for logging or reading anything over stock boost levels correct?
