R rb68rr Active Member Joined May 25, 2001 Feb 3, 2012 #1 Should the rod caps have any side to side play in them? On mine I can wiggle then just a little bit! How do I determine where the knock is coming from? Thanks, R.B.
N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Feb 3, 2012 #2 Yes, they must have side play. Since the pan is most likely off the engine, you will need to remove the rod caps to see if you have a bad bearing. Usually it is the upper bearing that gets hammered.
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Feb 3, 2012 #4 Cut the filter open... NE bearings "residing" there??? What did you see when you took the pan down?
