I am swapping a LQ9 in my 78 vette. Last year I purchased a 2004R heavy duty from Monster transmissions with a 2800 stall convertor with the lock out kit. Had this installed with a SBC 350. I have searched the forum and found most of my answers. The transmission is currently on the bench. Had a slight oil pan leak and will fix and also need to change the speedometer gear.
It shifted great up through the gears and downshifts fine until 2 to first around 10 mph or so, there has always been a slight banging? Is this normal or what should I check?
I never locked the converter up manually even though I had it wired up. Can this cause any damage?
