F FlaBoy Just a good ole boy... Joined Jun 6, 2003 Sep 18, 2009 #1 Surprisingly couldn't find this info anywhere... whats the proper torque spec for front wheel lug nuts? Thanks!
C charlief1 RIP Charlie! Joined Sep 20, 2007 Sep 18, 2009 #3 The specs from Firestone is 100 ftlbs. Either and you should be good. I used to work for them.
F FreeBoost Member Joined Nov 2, 2007 Sep 19, 2009 #5 charlief1 said: The specs from Firestone is 100 ftlbs. Either and you should be good. I used to work for them. Click to expand... x2 - as per op manual & shop manual
D DIAZ 87 2-1 FOR 2010 Joined Jul 15, 2007 Sep 19, 2009 #6 My aftermarket wheels are set at 80lb and the stock were at 100lb
