m/t sportsman pro
DR BOOST
Technical advisor
anybody running these? do u think they hook better than drag radials ?
thank you
surej
Better than drag radials but not as good as running a full on slick or ET Street (same compound but the Pro's have a slightly stiffer sidewall & smaller contact patch), BUT there are some tradeoffs!
1. Bad weather, forget about even trying to drive on them, may as well be on slicks
2. Treadwear is going to be about like running an ET Street, 1500 ~2000 miles IF you're lucky
Doug C.
I run my sportsman pros on the street in bad weather and no problems, can't even imagine doing this on a et street. That is the trade off I found. I was able to get the same 60 foot with the sportsman pro as an et street. Just my observation.
M/T sportsman pros are beter than et streets but still full slicks are better.
