A Aegis Member Joined May 2, 2009 Mar 21, 2010 #1 I just bought a used maf translator and it did not come with instructions. I am using a 3.5 inch ls1 maf. Does anyone know what the starting setting should be for the 4 white switches?
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Mar 21, 2010 #2 For a TT chip: ON,ON,ON,OFF in that order, MAF Base "0", MAF Wot "0" Eric
A Aegis Member Joined May 2, 2009 Mar 22, 2010 #3 Ok I have the settings on,on,on,off and the car idles fine, but when I get in the gas it sputters and then accelerates? Any ideas?
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Mar 22, 2010 #5 Check to see what code you're getting. My guess is code 34 (no maf signal).
A Aegis Member Joined May 2, 2009 Mar 22, 2010 #6 Thats correct I am getting a 34 code. The connector from the car doesnt seem to be fitting correctley into the translator harness. Ideas????
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Mar 22, 2010 #7 how many gray knobs in the translator? You may need an adapter harness, does the plug for the vehicle not fit "at all" or just not well? Bob
