Boostin TA
- Aug 27, 2005
Okay I need someone to point me in the right direction as to what I need to do. I finally got my TTA running but now the car idles like its running on 4 cylindars and is sooo rich that it bellows black smoke out the exhaust. Scanmaster is reading o2's between 130-240. Reving the car up still acts as if its "missing" No codes set. Map is reading approx 97-98 at idle. I tried adding and subtracting fuel in the Lo tune field at the low RPM range. I also tried putting after start up to 15, no difference. I also added and subtracted fuel from the main menu function. Absoulty no difference. I am not running a wide band. I have the Maft Pro set for speed density. Fuel psi is adjusted to 45 (I even cranked it down to 38psi and no real difference) I have the extender pro chip. Im at a loss as to where to start or what to adjust as I have never played with a self tuning device. I never let the car get into closed loop and warmed up as it is running so poorly I did not want it to contimate the oil. But it is so rich that the exhaust was burning my eyes! The car seriously acts like its idling and running on 4 cylindars and has a heavy missfire, however the car was running perfectly before switching over the the maftpro. Any Ideas as to what to adjust?
