Boostin TA
- Aug 27, 2005
This is for all the TTA guys out there running the Maftpro on their cars with the casper plug and play harness for a GN. What all is needed to get this hooked up correctly? I have everything plugged in properly, and the chip for the maftpro from full throttle. I called caspers and they told me that I need to wire in the seperate 6 pin harness that came with the maftpro and tap that directly into the MAP wiring. Anyone out there have the maftpro installed on a TTA? The problem I am having is a crank no start. And the Maftpro is only reading 1.1 for the MP sensor instead of 98-100. For full details see the computer chip tech section.
Thanks guys
Thanks guys
