I have a auto meter silver series 0-30psi boost gauge!Are you looking at the factory gauge or do you have an aftermarket set up?
D
Never been to the track car has stock bottom end with arp studs and bolts gn1 aluminium heads td rocker shafts lunati cam gn1 upper intake accufab 72mm throtle body gn1 adjustable fuel pressure regulator racetronix fuel injector harness edge product 60 pound injectors razor alky kit precision 5758e ball bearing turbo stock location gn1 intercooler gn1 3 inch downpipe with external westgate turbo tweak chip! I would say car feels like a mid to low 11 car!I don't think it's normal to be in boost to hold the speed limit on the interstate. Mods, stock, how fast is the car?
No realy in 4th gear but i have no lock up and geared 3.42 2800 rpm stallAre you sure of the RPM? It almost sounds like you are in 3rd gear. Maybe the converter is not locking.
Car runs smooth its an external wesgate on the downpipe compression is 150 in all cylinders boost gauge t's in the map sensor line!Unhook the w/g rod. Still show boost?
Where is the ga sensor/pickup point located?
At all cruise very smooth! And almost no pedle to stay at 65mph the problem is i am always in boost and it guzles gas like crazy cause of thatYou live in a place with no downhill roads! Try driving downhill for once. Just kidding. This is odd. Does it seem to take a lot of throttle to keep it at highway speed?
