J Johnnie Active Member Joined Apr 20, 2015 Aug 25, 2016 #1 yes, it's a stupid question, BUT..... When looking at a plain 87 regal master cylinder , which port is for the front brakes? The front port? Thanks in advance..
M malibudave1978 Member Joined Apr 3, 2005 Aug 26, 2016 #2 Rear port of master cylinder to front brakes Front port of master cylinder to rear brakes
J Johnnie Active Member Joined Apr 20, 2015 Aug 27, 2016 #3 Thank you. I'm wondering if we didn't hook them up reversed. My braking power is not as good as I think it should be, gonna check today...
M malibudave1978 Member Joined Apr 3, 2005 Aug 27, 2016 #4 The line fittings should be different so they should not hook up incorrectly. You should be fine the way it is.
