matching drop spindles and springs?
DragCamaro
Real-Keeper
What would you do to drop the rear level to the front if you have drop spindles and lowering springs? any pictures of how a car sits with it?
thanks, Mark
To bring the rear down to match the front height? I'd use rear springs from a 3rd or 4th gen Camarobird and cut the coils as needed. Those springs are only pigtailed on one end so cutting them is pretty easy anyway. Make sure you use the rubber upper spring mount pockets from the F-Body too.
