Max-Boost Launch Kit
1QUIK6
Max-Boost Launch Kit - I was wondering if anyone had purchased one of these kits? How good does this kit work? Problem- I can't seem to hold more than 3psi of boost while stalling. My converter is a Vigilante single disc lockup 3200-3400 stall. I also have the s-10 larger rear wheel cylinders with the larger soft brake shoes. Any other ideas?
You may not see any benefit, let me rephrase that: You will not see any benefit unless your brake system has no leaks, bled well, and is adjusted properly. The jumper valve will not overcome any weak links. I have a jumper valve and am still sorting out issues myself. A friend of mine used one and it worked great so it's all about the overall condition of the braking system.
