After some research and a few emails here and there. I may of found a Permatex product that maybe used instead of the GE1200 for sealing up steel shim head gaskets . It called "Permatex Super 300 Form-a-Gasket" . It is designed as stated on the container for "high-compression milled heads" , "resist pressures of up to 5000psi", etc . This product is a well known product used to seal steel and copper head gaskets in heavy duty commercial and Diesel applications from what I can gather . Also know as a old racers trick to use this stuff to seal up the steel gaskets in Big Block Chevy Race and Hemi engines with high CR years ago. before gaskets came out with coatings.
This stuff is like the "black goo from hell" and comes in a small bottle with applicator brush . Has anybody heard or used this stuff before ?
