We just got back from picking up the 84 t-type to be used in the development of the new intake conversion discussed here.
Car is clean, 58k miles but from what I gather from the previous owner, the cam is flat.
So here are what my plans are, looking for advice, suggestions, etc.
The goal is a mild street car for as little as possible, I already have a project typhoon, don't need 2.
206/206 cam (since stocker is gone)
replace all the main and rod bearings
double check cover for wear
new oil pump
new gaskets
new cam bearings
double check everything
I am figuring with the low miles and what the owner saw while replacing a head gasket engine otherwise is in good shape. I am assuming metal has not been kind to bearings though.
Anything else I should be looking for, or do while apart. I would like to see mid13's once we get intake, intercooler on but for right now I just need to get it running to get baseline #'s for the intake project.
new oil pump
new gaskets
new cam bearings
