Mr86t-type
- Feb 25, 2007
Guy's,
Really can't figure this one out, the car was running Great, with a Best MPH of 108.00 on my Stock Setup, but I was UBER LEAN, 740's n the 02 at the top of third, and only Mid-50's fuel pressure..So I installed a new pump, now I have
PLENTY of fuel, pushing 70psi and 810 and the Very End of third (Zero Knock of course).
So I upped the timing AND Boost from my previous 20lbs and 23/21 timing to 23lbs and 25/24 timing (0.0 retard), and went Back to the track EXPECTING better MPH...well Heres what I got instead:
Pass 1: 12.963@105.23 84.49 1/8th 0.2 retard 796 lowest 02 23PSI
Pass 2: 12.966@104.93 84.42 1/8th 0.1 retard 808 lowest 02 23PSI
Pass 3: 12.921@104.85 84.44 1/8th 5.6 retard 800 lowest 02 24PSI
I was FLOORED as Peviously, running OUT of fuel I was getting, an Average with LESS BOOST and TIMING:
12.800@107.50's 85.65 1/8th @ 20PSI and 24/23 timing with some knock 2.0-3.5 and 740's at the top of third
So WHAT NOW?? Pull Fuel from the Chip?? Turn the Boost Back Down??
The Weather played a MINOR role, as it was @ 85degrees/slightly humid, as opposed to 72degrees/not humid, but remember I had MORE BOOST and TIMING so that "SHOULD" have MORE than made up the Difference!!
