sorry so long...
I have been checking out the suspension converstations since April, but I still can't seen to figure some things out regarding sway bars, bushings and front end set.
My 87 GN has the original suspension. And it is real bad. Mushy and bouncy.
I am on a tight budget, so I decided to only upgrade the bushings, springs, shocks and sway bars.
For shocks, I found the Bilsteins at www.hotchkis.net for $55 ea.
For srings, I found the hotchkis 1" drop kit at www.summitracing.com for $250.
My confusion now lies with the sway bars and bushings.
For sway bars: I found the global west front (1 1/8" or 29mm) for $210 and rear (1" or 25mm) for $190. And the hotckis front (1 1/4" or 31.75mm) and rear (1" or 25mm) set for $329.
My quesion with the sway bar is I read that the mid 80's f-body has a 36mm sway bar that bolts right on to our cars. Is this true and what year/model is this exactly? If the factory front sway bar is 32mm, that is the same size as the hotchkis. Does size matter? Is bigger better or worse? What about the rear?
Now for the bushings:
I found the energy suspension hyperflex Complete Polyurethane "bushing" set for $159.
The PST polygraphite complete "front-end" set for $219 for regular and $359 for super.
The global west del-a-lum - front upper "bushing" kit $117 - front lower "bushing" kit $129.
What is the difference between the energy suspension and global west "bushing" kits and the PST "front-end" kit? What is the difference between polygraphite and polyurethane?
www.globalwest.net
www.p-s-t.com
www.energysuspension.com
Many thanks-
www.globalwest.net
www.p-s-t.com
Many thanks-
