Yup, my PTE 6262 with 100 miles on it ate itself for lunch last night. I took the car out and ran it up to 22# boost and 5700 rpms testing a problem that has plagued me for a year. At the end of the run I hear a 'werrrrr rrrrrr rrrrr clang clang' noise and back out of it immediately. Slow to almost a stop since there wasn't anyone out there in the middle of nowhere. I start moving again and cant get into boost....car runs fine but wont go into boost....limp the car 24 miles back home and stuff her in the garage for the night.
Next morning I go out and open the garage door and the drivers side front tire is flat. I laugh. Par for the course. I've driven the car about 1000 miles in three years and I have had to rebuild everything. Fix the flat and start thinking about what may have been the cause. I suspect turbo but dont want to go there. Pronto (thanks) says look at your turbo and I pull the air intake tubing off and sure enough...the shaft has major play and the impeller has kissed the housing.
Three things....manufacturer defect, lack of oil, or debri has gotten in the turbo. Not sure which. Will pull tonight and ship to PTE tomorrow.
I did not have a filtration system on the turbo but sure as heck will now! What can I do to minimize possible damage to the motor other than replace the engine oil/filter and blow the turbo oil feed lines out?
For that brief few moments I sure got a taste of a PTE 6262 at 22#'s of boost. Man, let me tell you...hold on to your friggin hats, folks.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
