I doubt the block lettering is original. It's commonly added afterward, mimicing the prototype. Supposedly they embelms were not ready when C&C converted the cars. There were legal issues to work through with NASCAR. The embelms where to be installed by the dealer. There was a template to place them, but I have never seen one.
Look at my avatar. Notice the arrow goes behind the 6. All the logos on the '82 GN are this way, except the fender/decklid emblems.
Looks like a solid and well kept piece....congrats on a great find and thanks for sharing the pics!
Was this logo on ther air cleaner?
I saw some sticker for sale on evilbay claiming it was.
built May of 1982 and delivered to Cars and Concepts of Auburn Hills Michigan for GN conversion on May 10, 1982
#34 of only 215 produced
documented in the 1982 Regal Grand National Registry
earliest known documented surviving Buick Grand National
Sweet! I would love to find a GN like that and throw my CT setup in it. Looks super clean! Last I knew there was a GN wheel and centercap on a car on a salvage yard grand prix. Knowing the place it wont be super cheap but if you really want that 4th cap next time I run down there I can see if its still there.
I'll be honest here since the tranny needs a rebuild. The rear gears should be a 3.23 but I'd check that just in case. If they are 3.23's then you might be able to go with a 2004R even though it's not original. It would give you better mileage and you could also go through the engine just to make sure it's good. A simple cam swap to something like a 204/214 would really wake the car up and still allow the puter to work without any issues.
One other thing is to see if you can find a set of the turbo hooker headers. They're a short tube type which work great in an NA application and and are short enough so you can do a single exhaust which helps with scavenging and give you more torque to help the car out.
This is the trouble with the registry - misusing it.
There is a list of 93 VIN numbers with the number and date they were recieved by Cars & Concepts. The order they were recieved is not the order the the were produced on the assembly line. This car, #34, happens to be the lowest number on the incomplete list. It is not the earliest known surviving '82 GN by any strech.
There are 33 other cars with lower conversion numbers. And as far as VIN numbers go, it was built in the middle of the 215. I can account for 73 cars with lower VINs than this car.
No, the stickers on ebay are for the turbo engine, whether in a GN or not (Sport Coupe). You will find it very common for folks to call all 1982 Turbo Regals "Grand Nationals".
The block lettering on the fenders is not the work of C&C or Graphik Concepts.
