Silver Fox
- Apr 17, 2003
jack up the front of your car, put jackstands on both sides. Put your jack under the lower control arm and jack it up to load the suspension. Take out the cotter pin on the ball joint, loosen the bolt about 1", and slowly lower the jack. The spring will do the work separating your ball joint. when you undo the two splined bolts attaching the uppers to the frame, make sure you don't strip the splines, it'll be a pain to reinstall. Also make sure you take the shims and remember where they were and in what order. A zip tie works well to secure them together if you are going to take a while. Then, just bolt on the upper arm, put in the shims, attach the ball joint, and put the cotter pin back in. Piece of cake. Oh yeah, don't forget to take the wheels off...
Thanks for the tips. I will probably just replace the splined studs with some grade eight bolts (per this month's PHR and advice from SC&C where I bought the UCAs from).
I am also going to throw on some Baer brakes I have had lying around the garage, and I will also be replacing my lower ball joints, lower control arm bushings, and my idler arm.
Thanks again,
Rob
