My TURBO6 project
got the drivers side notch all done! I also picked up some blazer spindles. Had my buddy sand blast them. Then I sanded them down
Picked up some umi Coilover only upper and lower a arms
I also got my calipers sand blasted.
Coilover comes out from the bottom so no need to take the tire and spindle off
Nice work! Keep it going. I have an 90k mile 86 GN that is getting a little tired...thinking about a restore but I like to drive it and I know it would take me at least 2 years.IMG_20190713_110122[1].jpg
soon as I get the I’ll be taking the corvette logo off and putting this on
Very nice!!! Are those high temp decals?
I wanted to do something like that with my C5 (base) setup, but the local sign shop only had 200 deg. vinyl, so I had them make stencils and used wheel paint.
No they are not. I’m getting the caliper Powdercoated then outing the sticker on. Then I’m getting a clear coat Powdercoat over it all to seal it
How do you like the stopping power of those? You ever thought about upgrading? Those look nice too
I upgraded from stock to these with ceramic pads. I haven’t run them yet. I want to modify the rear SSBC brackets so I can run off the shelf ‘86 C4 11.5” front rotors (on the rear) instead of turning them down to 11.1” as per their kit. I’m doing other upgrades while I’m at it and waiting on wheels. Thank you.
Turbo 6 is back from Powdercoat!!!
Slowly I have been busting out parts I purchased thru out the years
I’ve been working in the rear end also!
