If you're currently running a factory alternator, one commonly overlooked difference is most aftermarket alternators will come with a different size pulley than your factory unit.I need an alternator. Only have 12.4 volts at wot and don't want any of those "voltage boosters". Who rebuilds them or where do I get one that will work properly? Anything special about our alternators or can I just go get one from autozone?
Which one? something like this? Does it just plug right in? Trying to get back up and running quickly. Car is adding a lot of fuel as the voltage is way low. https://www.autozone.com/batteries-...tor/p/valucraft-alternator-1386-6-7/13522_0_0I used the 96 Impala ss alternator.
A buick or impala one?I recently got a Remy unit from Rockauto. $80 and it’s perfect. 14.2 volts
Buick. Looks just like originalA buick or impala one?
Are you getting that 14.2 volts at speed warm? My alternator puts out 13.8 at startup and falls to 12.2 as it warms up.Buick. Looks just like original
Just went for a spin in the goonie wagooon to check it.Are you getting that 14.2 volts at speed warm? My alternator puts out 13.8 at startup and falls to 12.2 as it warms up.
