Need help diagnosing vehicle getting sucked into any groove in the road
geenex
MEMBER
I have an 86gn that gets pulled into any rutt or grove in the road. I have replaced every bushing and joint in the front end -the steering box is a new reman-the rag joint is new-the power steering pump is a new reman-i have gnx wheels and tires. What do you think?
Mine does the same thing same wheels, I think it's the wide tires, I put my Telstars on with skinny tires and no longer tracks the road.:)
What are your tire sizes front and rear? What did you set your alignment specs to?
If its "touchy" have your alignment guy play with the caster/camber. Otherwise, yes, wide front tires will cause this as well.
the front tire size is 245/50r16 rears 255/50r16
left frt rght frt
camber .6 .2
caster 2.7 3.0
toe .17 .15
crosscamber .4
crosscaster -.3
total toe .32
WHAT DO YOU THINK?
Looks to me like your left front camber needs a little adjustment. Are these specs from your alignment or did you have them measure it? I'll dig up a little more info on where exactly you need to set it up to. Your rears tires arent really really much wider than your fronts so that wont have a huge effect. How are your ball joints? Also, this may soud stupid but check to make sure your lug nuts are tight. On an aluminum rim, hey have a tendensy to work themselves loose.
left frt rght frt
camber .6 .2
caster 2.7 3.0
toe .17 .15
crosscamber .4
crosscaster -.3
total toe .32
WHAT DO YOU THINK?
I think you just explained why the car is all over the road. Did you look at the link I posted for you? Cross caster won't hurt you but the camber is screwed to say the least. The tire has to be flat to work the best but a .1 negative is the best if you're sitting in the car when it's done. The chasis will change when you get in it or add weight. Since you're at a positive it will be worse. You need to find someone that actually know about a performance alignment. The wide tires are effecting the way the car goes down the road because they will pick up every grove unless you compensate for it.
Eh, I would personally be looking only at camber and toe. Negative camber will affect tramlining in a big way. I would also try pulling that toe in a bit. The more toe out you have, the less stability in a straight line you will have.
Most ruts in the road are narrow. My GN with 235 60 15's seems to ride fine. One the same road, my 245 45 17 T has some wander and is more of a handful. My Z06 with factory spec alignment and 275 40 17 up front and 305 35 18 out back it requires both hands on the wheel...
Wider tires are aggravated by grooved roads, and will cause a vehicle to pull more. The 'Vette should be worse than the other just because of the factory alignment. The have a lot more "factory" Negative camber and toe out to increase handling and responsiveness. Pair that with a set of decent sized meats in the front, and the car is going to have a mind of its own.
Yes my 99 SS camaro has 275/40/17's all around an it finds all the big ruts.
The TTA does it a little but not as bad as the camaro. and the GN has 3.5 wide front wheels so it doesnt track at all :cool:
Thanks for your input. If i understand everyone correctly, i'll set camber left and right to .1 negative with vehicle weighted for driver. Caster to 4.0 degrees right and about .3 less on left side. Finally pull toe in slightly.
This is way to high for a street dirven car. It will cause edge wear on the tires both inside and outside. You'd be better off with a 3.25 on the passengers side and .4 lower on the drivers side. This will keep you from killing the tires when you go around the corners. The toe may be OK with more toe in but you need to check and see how much play there is in the linkage to make sure it's not going to cause toe in wear.
i dont know the exact age. they were on the car when i bought it. they seem to be in good shape-good tread/no dry rot
Personal story - rebuilt my entire front end with some high end components and car still tramlined all over the place when there were grooves in the road.
I replaced the tires (which looked good and no dry rot) and the "T" tracked fine afterwards. Don't discount the tires as being part of, if not all, of the problem (especially if they are directional). I put asymmetrical tires on my car.
To this day, I wonder if I even needed to rebuild my front end - although the SC&C stage II kit is nice.
Rob
I too have been all through my suspension trying to fix tramlining. I found that caster, camber, toe, had less to with it than tire width and specifically wheel offset. Wheel offset affects the scrub radius. Basically the factory geometry was designed for skinny wheels and ease of low speed parking. When you put a wider wheel on, even a factory GNX wheel it changes the scrub radius. The Hunter guy who services our alignment rack at work got me looking at this. In the end, I want the car to look good so I deal with it. But definitely get your alignment specs right as it does help. I'm also looking into bumpsteer's affects on this as well.
