Car cranks but no start.
Fuel pressure good. Fuel pump primes with key on.
Check engine light on with key on.
No spark
No fuel injector pulse as checked with a noid light
Confirmed 12+ volts on both pink wires at the end of the C3i
Not quite sure what to check next. I think I've made it up to step 8 on the No Start Troubleshooting tree, but I'm stuck here. If I apply 12 volts to the connector (not the ignition module side) my noid light on the injector plug does NOT light. If I understand this step correctly.
What else should I be checking?
No spark
