So I bought a car from a member on here and didnt like the set up so I re-worked it. While I ripped the car apartI fixed numerous isues:
Broke water pump bolt, no bolts in the intrcooler, freyed surpintine belt, wiring looked like a birds nest, 2 of 4 guages didnt work all the time, blah, blah, blah. etc.
I then dumped the oil, checked all the grounds, replaced the spark plugs, replaced the injectors.
The car has a forged stroker motor with all the bells and whissles. 215/218 roller cam,gn1 ported head, 6265 turbo.
I then ordered a new twin nozzle alky kit, a power logger, and the matched 6.1 turbo tweek chip, and attached a plx wide band. (scan master was there already)
I cannot seem to get the car to go past 10psi without breaking up. I figured with the wide band, matching chip, powerlogger and new alky kit I would be close, but no. The chip is supposed to be set up for 24psi..... no way I can run tht now. I tried to check the health of my fuel pump and it seems to start at around 39psi and go to 49psi at wot..... is this normal?
The car runs fine until 10 psi or so (rolling into the throttle) then is breaks up and shows a small amount of knock (like 2-2.5 degrees) I immediately get out of it.
I tried adjusting the base fuel pressure up to 142 (cel 4) no good (althoug it changed the reading to 128)
I tried pulling 10 degrees of timing in 1-2 and 3-4 ...... no good
I made sure my fuel pressure eg was set up at 43 psi at idle
I have not touched cells 1,2,3 becuse im not sure how to adjust them.......
Also I thought the whole reason for the widebanwas so you could be close and still get by on the correction factor. How do I make sure its referencing the wide band? or is that the default? The afr reading is appearing on the logfiles.
HELP!
HELP!
