I have an 83 regal that has been sitting in the garage since last year. Car runs great but I just realized that my headlights are not working. All other lights work except the headlights. I tested to see if there is power to them which there is not. My only idea where there may be a problem is my high beam switch is broken therefore the high beams don't engage when i pull the lever back, which is on my steering column. Does anyone have any ideas if that could be the reason my head lights don't work? All fuses are fine. I also tested the yellow wire that goes from my headlight switch to the high beam switch and that works. One other thing is I do have power coming out of my headlight switch. The only wire that I don't have power on is the small brown wire that feeds my headlight. I'm lost and I can't drive this car at night until I fix this. TYIA
#1A moment ago
#1A moment ago
