shouldnt have to post this as you already have the info available right under your nose
..its in the ccom program under help > index>section 27.0 diagnostics look at list under 27.3.3
16 is wideband fault
your uego (v) at 3.52 means the o2 sensor isnt connected
uegos (v) at the volt posted means the sensor heater has issue (would read .45 if OK , 1.1 would be if its not heating up or disconnected)
Sorry guys forgot to get the details when I picked up the car, here is a picture. He says he had to switch all the wires on the connection in the photo below so they match.
