buicktom61
- Jul 18, 2014
Hello,
my name is Thomas and I live in Germany. Since July I am a proud owner of a 86 GN. Bought it on ebay with a rebuild engine ( Diamond Pistons .030, Comp. Cam 212/212, new valve springs, rebuild heads, Chain and sprockets).
After its arrive in September I had a great ride back home from Bremerhaven. After I pulled the last main bearing, because of a massive oil leak, I found bad main bearings. Engine was rebuilt but Maschine shop didn't clean the oil pump and the oil cooler. So a lot of dirt went through the engine again.
Now the engine has all bearings new. While the engine was at the Maschine shop, I bought some goodies.
Here is the list:
TE-61 Turbo
G-Body stock located IC
60 lb injectors from TRE
adjustable fuel pressure valve
Walbro fuel pump
fuel pump hot wire kit Caspers
upgraded TT-Chip
RJC-Powerplate
G-Body 3" downpipe with free flow 2 line 2.5" exhaust
The heads and the intake manifold are mild ported.
Intake has a 4"K&N cold air intake with stock 3"MAF.
That's the combo I have now, but I am not sure if I did it right or if I have to do some more changes.
The Transmission was upgraded with a shift kit and the torque convertor is a re-stalled D-5. I don't know if it fit with the Turbo.
The only thing I want is fun on the road. No races.
Any suggestions appreciated.
Greetings from Germany
Thomas
Here is the list:
TE-61 Turbo
Walbro fuel pump
upgraded TT-Chip
RJC-Powerplate
Thomas
