87 WE2
- Jun 28, 2002
Stupid question that I don’t have the answer to because I'm not an AC guy.
I am rebuilding the front end of my car and installing a new compressor, lines, accumulator, condenser, seals, & orifice in the process. I have 20lbs of old school good DuPont R12, not the freeze 12 junk.
The car has always had R12, still had a little charge when taken apart but not much due to bad seals. So I should not need any conversion oil, orifice was clean so there was no junk in the system.
I would like to use the R12 I have, with that in mind
I need to know:
What oil to use with the R12?
Where to get the oil if anyone knows?
How much oil to use?
I have read some should some go in the accumulator, and some in the compressor? If this is the case how much in each and what port of the compressor? Does it matter for the accumulator where to port to put the oil in?
I do not plan to charge it myself I will have that done but I wanted to get the oil and put it into the system as I reassemble it.
Thanks for any help. -Ed
I need to know:
