Z zam70 ->ROGUE Joined Aug 6, 2001 Aug 26, 2005 #1 Rebuilt the shortblock... What is the general thought on Valve timing/degreeing? Straight up? advanced? retard? Cam is the Ramchargers race cam (224/224) Thanks Scott
R RICHIE HIGH PSI Active Member Joined May 25, 2001 Aug 27, 2005 #2 Straight up as most of those race cams are cut with a little advance in them. Richie
F frankg Speed Seeker!! Joined May 24, 2001 Aug 27, 2005 #3 You need to degree the cam as per the cam card to make sure it is set correctly. Sometimes they will be off 3-4 degree due to a chain or gear off a bit. Frank
