T turbo2nr loading... Joined Aug 28, 2004 Jun 12, 2017 #1 Looks pretty so far? I bought on eBay for $110 each (shipped) 10.5LBS FOR ONE.... Last edited: Jun 12, 2017
T turbo2nr loading... Joined Aug 28, 2004 Jun 12, 2017 #2 21 Pounds for both. I believe this is maybe 1lb heavier than what I am about to take off?
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Jun 12, 2017 #4 Still lighter than cast iron, no? I just weighed a used set of OEM aluminum ones that I'm about to have turned. Just under 21 pounds. Last edited: Jun 12, 2017
T turbo2nr loading... Joined Aug 28, 2004 Jun 12, 2017 #5 Yeah.... I read a thread here that stated Stock was 10# and Aluminum 5#. That is not true. The Stockers are around 15# and Aluminum 10# So, indeed a total savings of about 10# rotational mass.
T turbo2nr loading... Joined Aug 28, 2004 Jun 12, 2017 #6 Your wheels will get pushed out another 1/8" - 3/16" or so? The facing of the Aluminum is a bit thicker than the Irons. Which is what I needed. I guess Two thumbs up so far. Last edited: Jun 12, 2017
G gusszgs Active Member Joined Dec 9, 2007 Jun 12, 2017 #7 Got a set of aluminum drums from Kirban this year. Home scale weighed the aluminum's in at 9.5lbs and my cast stock ones where 15lbs So yes , the aluminum drums will save you 10-11lbs a set.
B Bob Lob-Law Member Joined Apr 13, 2011 Jan 6, 2018 #8 https://www.carid.com/cardone/selec...MIm4TFq7TD2AIVhaDsCh3irwa5EAQYAyABEgIlsPD_BwE
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Jan 6, 2018 #9 Bob Lob-Law said: https://www.carid.com/cardone/selec...MIm4TFq7TD2AIVhaDsCh3irwa5EAQYAyABEgIlsPD_BwE Click to expand... That link doesn't work. Just Google cardone/select-aluminum-brake-drum
B Bob Lob-Law Member Joined Apr 13, 2011 Jan 6, 2018 #10 Sorry about that. Try this one: https://www.carid.com/cardone/selec...MIm4TFq7TD2AIVhaDsCh3irwa5EAQYAyABEgIlsPD_BwE However, I found them cheaper on ebay.
