New from TA Performance, the TA V2026 `86-`87 231 Turbo, Internal & External balancer with removable counter weight.
TA Performance has just reproducted the stock 231 Turbo Balancer. This balancer can be used on Internal or Externally balanced rotating asemblies. The counter weight is removable as you can see in the picture. Comes with pick up wheel installed, marked with TDC, 25 degrees Before TDC, 25 degrees After TDC, and best of all, it's SFI Approved.
Intro priced at $289.95
Click Pictures for Larger Image
