Lee Thompson
- May 24, 2001
correct
Mount an 87 turbo on you 84-85 intake bracket, measure to the depth of the adapter socket in your 84-85 intake, cut the necessary amount off the adapter or the tubo or both to come out with the necessary length. BTW keep it about 1/16 to 1/8 short. The O-ring has of plenty room to seal. I am sure Chopper will build you a turbo then. I don't know what compressor wheel the 54 has in it. I would think a 60mm wheel in an 87 unit would be more than enough. BTW you MUST bore your TB to match the size of the turbo inlet. Best of luck. It is not brain surgery!!!
The only time a tubo is too big is when you can't close the hood.
