This is my second Turbo Buick, First one was 20years ago. My car is getting alot of Audible detonation at Part throttle boost (8 to 10lb) I have to let off) around 15* Knock retard, O2 were at 828, BLM 128 according to scanmaster. I have changed Plugs to cr43s, new fuel filter, Wires, checked for vacuum leaks. Fuel pressure is set at 44 line off, It does have a TT street chip and I have talked to Eric and says the Chip should be Ok for setup. I think I am going to have to check a few things but not sure where to start.
Motor stock, PE61,42lb injectors,Mass Pipe & K&N, Adjustable Reg and 340 fuel pump, PT3000 stall, 3inch down pipe and magnaflow exhaust.
